My Lexus Portable Plus Cell Phone was stolen :censored: along with my backpack. Anybody know where i can purchase another one. I already have a integrated system just need the mobile flip phone that fits in the middle cradle.
LIONSCOURT
that looks like a motorola base
you can use any motorla model like it you don;t need the lexus one
btw only post one question in one section next time
You still use the factory phone? Isnt that analogue? You can still find service for that? I have a handsfree in my car... Never thought to hook it up.
Anuhome,
1. Pull all remaining apparatus from the center console, thereby greatly increasing storage.
2. Acquire a digital/cell phone that dose not need to be hard-wired to your car.
I really like the extra storage gained from removal of the large, antiquated phone.
EVV
Thanx for the responses folks. But i wanted to use the handsfree aspect of my car phone. I definitely agree that i need to update but what would be compatible with the handsfree aspect through the steering wheel and stereo? What would be the best update? By the way i never had the phone hooked up but was planning on doing it soon. And it is a 97-SC400.
Thanx
LIONSCOURT
I took the my 97 sc4 into dealer today and showed him phone cradle and manuel. He told me what BMan113 knew, that it is analog and useless. Thanks for the info though. He also said that they went digital in 98.
Take care
anuhome,
Since you already have the wiring for the Portable Plus, it would be a bit easier to hook up a car kit for a phone - even a Bluetooth kit. If it is like my LS, the plug under the console to which your handset base is connected contains both an audio system mute point and power. It may even contain terminals for playing the call through the radio speakers but I never bothered to check. It may be possible to cut the wire harness that runs from your Portable Plus handset base to the connector under the console and connect some of those wires to power a phone car kit and mute the audio when a call is received or made. You could determine which wires are power and which one is mute by testing the wires with a 12V test light. You might have to remove an in-line booster in the trunk (assuming that your's has one) and plug the connectors the trunk together as if the car never came with a Lexus phone.
This doc shows the connector under my center console to which I connected the mute wire for my Nokia kit. In hindsight it would have been simpler to have powered my Nokia kit from this same connector.
http://home.kc.rr.com/colchester/phone/Nok...H%20install.doc
I doubt if it is realistic to expect to use the steering wheel controls. The voltages required to control my Nokia are too complex for me to build an interface to the steering wheel controls and the voltages probably vary by phone.
