steviej Posted August 13, 2004 Share Posted August 13, 2004 This is what is in the 2002 ES manual. Fuel selection: Select premium unleaded gasoline with an Octane Rating of 91 (Research Octane Number 96) or higher for optimum engine performance. However, if such premium type cannot be obtained, you may temporarily use unleaded gasoline with an Octane Rating as low as 87 (Research Octane Number 91) steviej Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 13, 2004 Share Posted August 13, 2004 your gas milage is probably because your egr set of the cel which is stuck closed so it is not a gas issue but it is an egr problem which would rectify your issue the problem is carbon from running cheap gas has clogged it and it needs to be cleaned out Quote Link to comment Share on other sites More sharing options...
amf1932 Posted August 13, 2004 Share Posted August 13, 2004 The wording was changed in the '03-'04 manual as you can see above. ;) Quote Link to comment Share on other sites More sharing options...
