gogo_sc300 Posted July 26, 2004 Share Posted July 26, 2004 I just got my SC300 last thursday night and had to drive it home (about 120 miles :D ) and I notice that when the cruse control was set to about 70ish the tach was reading a little of 4 grand. Just wondering if this is normal for this car? Seemed a little high but I'm used to a five speed with tall gears. (my geo) I have a 92 Sc300 with an automatic tranny. Quote Link to comment Share on other sites More sharing options...
soarer479 Posted July 26, 2004 Share Posted July 26, 2004 yea that sounds pretty normal to me Quote Link to comment Share on other sites More sharing options...
alexR Posted July 26, 2004 Share Posted July 26, 2004 my GS is a quite a bit lower than that, and im quite sure it has the same gear ratios. Is your O/D off?? Quote Link to comment Share on other sites More sharing options...
UCF3 Posted July 27, 2004 Share Posted July 27, 2004 Didn't quite catch it, but are you driving a 5sp or an Automatic? 5Speed sounds right, on the Auto it should be a little bit less since there's overdrive. Quote Link to comment Share on other sites More sharing options...
alexR Posted July 27, 2004 Share Posted July 27, 2004 is the SC's fifth gear really that short? surely not...? it just seems that 4000 in 5th should be a little faster than 70. Quote Link to comment Share on other sites More sharing options...
soarerTT Posted July 27, 2004 Share Posted July 27, 2004 i have a 5spd 300 and that sounds about right to me, not exactly sure so ill check, but i just remeber i thought the same thing for a while, (used to high redline of hondas) but its normal Quote Link to comment Share on other sites More sharing options...
gogo_sc300 Posted July 27, 2004 Author Share Posted July 27, 2004 Thanks for the info. I do have the auto and my O/D is on. I looked up the final drive of the auto....with 4.27:1 it sounds about right. Just to let you know I went from driving a 91 geo metro to my sc300 so it's going to take a little getting used to. Quote Link to comment Share on other sites More sharing options...
llama Posted July 28, 2004 Share Posted July 28, 2004 gogo, It sounds like your OD is off! Inspired by your post, I took my sc300 out and took note of the RPM w/ OD ON & OD OFF. This is the listing w/ OD OFF: 40 mph ~ 2200 rpm 50 mph ~ 2750 rpm 60 mph ~ 3250 rpm 70 mph ~ 3750 rpm w/ OD ON 40 mph ~ 1500 rpm 50 mph ~ 2000 rpm 60 mph ~ 2250 rpm 65 mph ~ 2500 rpm 70 mph ~ 2750 rpm 80 mph ~ 3000 rpm My car is a 96 w/ auto and the rims & tires are the proper size. I get great mileage as well, usually 28 MPG highway (75-80mph) and city somewhere around 23-24mpg. If the light is on in the dash, the OD is OFF. You might want to check your OD button as well. Mine was broke when I purchased my car but w/ OD ON. It is an easy fix! Quote Link to comment Share on other sites More sharing options...
alexR Posted July 28, 2004 Share Posted July 28, 2004 I also did something similar, except i tried to take it to 4000 in 4th gear just to se how fast i was going. After I hit 90 (and still under 4000) mi thought i should slow down. Moral of the story: 4000 RPM's is very high for 70mph. Quote Link to comment Share on other sites More sharing options...
gogo_sc300 Posted July 29, 2004 Author Share Posted July 29, 2004 Strange I know that my o/d is on...when i push the button the o/d off light turns on and I can feel the car lose a gear. I have accidently done this on the freeway and the rpm's shot up. :chairshot: I still get about 25mpg freeway driving. My 92 only has a 3 speed w/ O/D right? Also could my tach just suck? I know that they can be inaccurate at times. Quote Link to comment Share on other sites More sharing options...
BlackSC4 Posted July 30, 2004 Share Posted July 30, 2004 does the car need a tune up? old air filter maybe? maybe the person who had it before tweaked with the throttle a bit. does it idle at about 700rpm? Quote Link to comment Share on other sites More sharing options...
god329 Posted July 30, 2004 Share Posted July 30, 2004 i know my car redlines at 90 in third and its a 92 5 speed so 4 grand in 5th is way high Quote Link to comment Share on other sites More sharing options...
llama Posted July 31, 2004 Share Posted July 31, 2004 gogo, how large are your wheels and tires? This could have a slight bearing. Can you hear your engine at all? If you rev it in N or P, does the tach move according to the engine sound? Also, is your speedometer accurate? Whenever I have driven these cars, the difference between 60mph and 90mph does not really feel that much different! They stay butter smooth at high speeds! Quote Link to comment Share on other sites More sharing options...
gogo_sc300 Posted August 2, 2004 Author Share Posted August 2, 2004 Sorry it took so long to get back to you all.... If I had a five speed I would be very worried but I have an automatic. My tires and wheels are stock dimentions so don't think that's the problem. But the more I drive my car the more I'm starting to think that the tach just isn't very accurate. When I'm crusing around and let off the gas my rpms dorp by about 700. My engine is still running and it's not a drop due to a shift. I can feel the car go through all it's gears. I think that my speedo is right, when I set my cruse control I'm not flying by anyone. My car seems to idle at about 1050 or so. I have a good friend who's a cop and he's going to check out a radar gun and help me out :D . I may just get an aftermarket tach. Anyone have one that isn't the size of a coffee can and can post some pic's of where you put it? Quote Link to comment Share on other sites More sharing options...
gogo_sc300 Posted August 14, 2004 Author Share Posted August 14, 2004 Sorry it's taken me so long to post an update.....Well my tach just sucks. I was crusin' algon about 45 and decided to floor it. The car shifted down and (if my tach went that high) hit about 9 grand . So a (dim) light went on in my head and I thought to my self well that solves that problem. Who really needs a tach when you driving an auto anyway. Quote Link to comment Share on other sites More sharing options...
jzz30 Posted August 15, 2004 Share Posted August 15, 2004 so you have a honda motor in your lexus yea you dont really need a tach in an auto. ;) Quote Link to comment Share on other sites More sharing options...
