Bleeding The Brakes On A 95 Ls400
streetkit
as far as i know its the same, but if you want i will check the factory manual when i will get home on sun and i will give you whole procedure.
Basically same as every car---just DON'T let the master cyl run out of fluid. need 2 people; 3 better[unless you have a 'sucker']~~~~~~~that is a MECHANICAL sucker; then you still don't let the fluid run out.
If air gets in the ABS due to fluid run out--it is tough to get out.
I suspect that there is some air in my system as the brake pedal is pretty soft. Brakes work great but the pedal seems soft and goes a little to low for my taste. Of course I'm comparing it to my SC400 which may not be a good thing to do.
The previous owner had the master cylinder replaced about two or three months before I bought the car. However, it was done by a Pontiac dealer????? :whistles: :o (I guess the service manager was a friend of his)
So I was wondering if they screwed up.
