On my 92 LS key, it has the LEXUS logo, and then on the side there is a button that is barely visible, but it's made of rubber and you can press it. what does it do?
it is the stock oem lexus alarm
if it doesn;t do anything like unlock the doors
tehn the battery is probably dead
I don't think its broken. I have two other remote keys, that have new batteries, and they both can't lock/unlock the door. I think it's something with the car. :(
It's most likely the head unit. It might be out. I had the same problem with the LS, and I had to replace the entire unit. It cost me $350 w/labour.
I did mine through the dealer about three years ago. Labour rates have gone up since then, so I'd get a price quote.
Mine dont work,replaced batteries,ive been told its the main unit in the car...
For the price Lexus want to replace it...im just going to have a alarm fitted ;) that will lock/unlock the doors and should have a better distance range.Over here i can get a alarm fitted for £100 cheaper the the Lexus replacement unit which i believe the range is only around 3 feet :unsure:
