Grandpa Posted July 12, 2004 Share Posted July 12, 2004 Does anyone know the procedure to get the error code out of a 1992 LS 400 for the trac and CHECK light? And does anyone know how to interperet these codes? Quote Link to comment Share on other sites More sharing options...
pachocco1 Posted July 13, 2004 Share Posted July 13, 2004 http://www.troublecodes.net/Lexus/ Quote Link to comment Share on other sites More sharing options...
Grandpa Posted July 13, 2004 Author Share Posted July 13, 2004 Im driving a 92 ls... that is 96 and later Quote Link to comment Share on other sites More sharing options...
1UZ-FE Posted July 13, 2004 Share Posted July 13, 2004 Im driving a 92 ls... that is 96 and later nope. you misread. Accessing Diagnostic Trouble Codes 96 & later are OBD2 systems. scroll down 1 page till you see: Without OBD2. OBD=On-Board Diagnostics. the very top of the page tells you step-by-step exactly how to retrieve error codes for a vehicle without OBD2. vehicles 96 and later all have OBD2 which can be accessed by a scan tool. Quote Link to comment Share on other sites More sharing options...
Grandpa Posted July 13, 2004 Author Share Posted July 13, 2004 So im gunna need to buy a tool to read the error codes ? Quote Link to comment Share on other sites More sharing options...
tansupplyman Posted July 14, 2004 Share Posted July 14, 2004 Not if you can see the engine light blink at you and can count!!!! Here is what the website said :: ""On pre-OBD II models, turn ignition to On, then use a jumper wire to connect terminals TE1 and El of the data link connector, located under the left hand side of the instrument panel. Codes are indicated by the number of flashes of the check engine warning light. Reading Trouble Codes If the ECU has detected a system malfunction, the check engine light will blink every .5 second. The first number of blinks will equal the first digit of a two digit diagnostic trouble code and after a 1.5 second pause, the second number of blinks will equal the second digit of same diagnostic trouble code. If there are two or more DTC's, there will be a 2.5 second pause between each. After all DTC's have been output there will be a 4.5 second pause and all DTC's will be repeated as long as the terminals TE1 and El of the data link connector are connected. In the event of two or more DTC's, indication will begin from smaller numbered code and continue in order to the larger. After all DTC have been recorded, remove jumper wire. Clearing Trouble Codes After service, the diagnostic trouble code or DTC's retained in the ECU memory must be cleared by remove the EFI fuse for approximately 10 seconds or more, depending on ambient temperature (the lower the temperature, the longer the fuse must be left out) with the ignition switch off. The OBD II scan tool has a feature to clear DTC's. Refer to the manufacturer's manual for procedures. DTC clearing can also be done by removing the battery ground cable, other memory systems (clock) will also be cleared. If the diagnostic trouble code is not cleared, it will be retained by the ECU and appear along with a new DTC in future trouble codes. If it is necessary to work on engine components requiring removal of the battery ground cable, confirm no DTC's are stored. After clearing codes, road test the vehicle to check that a normal operation. If the same diagnostic trouble code appears, the trouble has not been corrected. Without OBD2 [pre '96] 12 RPM Signal 13 RPM Signal 14 Ignition Signal 15 Ignition Signal 16 Electronically Controlled Transmission Control Signal 17 CMP No. 1 18 CMP No. 2 21 Main O2S & Heater Signal 22 ECT Sensor Signal 24 IAT Sensor Signal 25 Air–Fuel Ratio Lean Malfunction 26 Air–Fuel Ratio Rich Malfunction 27 Sub O2S Signal 28 Main O2S 29 Sub O2S 31 & 32 Air Flow Meter Signal 35 HAC/Barometric Pressure Sensor Signal 41 TP Sensor Signal 42 VSS Signal 43 Starter Signal 47 Sub TP Sensor 48 Secondary Injection System Malfunction 51 Switch Condition Signal 52 KS Signal 53 Knock Control Signal 55 KS Signal 70 EGR System Malfunction 71 EGR System Malfunction 78 Fuel Pump Control "" Quote Link to comment Share on other sites More sharing options...
Grandpa Posted July 14, 2004 Author Share Posted July 14, 2004 Alright, i understand, but where exactly is "the instrument panel?" Quote Link to comment Share on other sites More sharing options...
VMF Posted July 14, 2004 Share Posted July 14, 2004 thats where all the instruments are (eg tach, temp, fuel etc.....) ;) :D Quote Link to comment Share on other sites More sharing options...
