eman_be_lexin Posted July 6, 2004 Share Posted July 6, 2004 Here is a crazy situation. I have been having problems with my windshield washer fluid sensor. The light has been on in my dash for 2 years. I have yet to get it looked at because it was not at the top of my priority list. Yesterday I noticed that I used my washer and the light went out. I figured the problem was resolved but I was wrong. When I filled the reservoir the light came back on. The sensor is working backwards. Indicator on when the tank is full and indicator off when the tank is empty. Do you think I should replace the sensor? I found where the sensor is located when changing my fog lights in the bumper. Quote Link to comment Share on other sites More sharing options...
jay swinger Posted July 6, 2004 Share Posted July 6, 2004 My guess is that the sensor DOES work because you get a different indication when it is empty than when it is full. What has happened is that two leads have been reversed so that you get the light on when it is full and the light off when it needs refilling. Changing the sensor should not change that. My opinion is that there is a simple correction needed in wiring. Two leads need to be cut and swapped before re-soldering. The electrician could also check it before resoldering to be absolutely positive this was the case. Quote Link to comment Share on other sites More sharing options...
eman_be_lexin Posted July 6, 2004 Author Share Posted July 6, 2004 That's a good idea! Thanks Jay Quote Link to comment Share on other sites More sharing options...
bdonkersgoed Posted July 6, 2004 Share Posted July 6, 2004 How on earth could these leads get reversed in the first place?? Wires don't just rearrange themselves on their own . . . Regards, Bryan Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 6, 2004 Share Posted July 6, 2004 If the car was in a front end crash it may have been damaged or incorrectly repaired. It may either be shorting the wires somewhere around the bottle. Try disconnecting it and see what happens. the year might have helped also Quote Link to comment Share on other sites More sharing options...
steviej Posted July 7, 2004 Share Posted July 7, 2004 another possibility is if the sensor is a float type sensor, then the sensor itself may have been installed in upside down. The wiring is correct, but the orientation of the float is wrong. When the tank is empty the float is hanging all the way down and not making electrical contact to light the empty light. When fluid is added the float is forced upward and the electrical contact is made, thus lighting the empty indicator light. just a thought. steviej Quote Link to comment Share on other sites More sharing options...
eman_be_lexin Posted July 8, 2004 Author Share Posted July 8, 2004 I was involved in a front end collision and I noticed the problem right after I picked the car up. I contacted the dealership where I had it repaired and they told me that the reservoir wasn't damaged. I am going to try to disconnect the sensor and play around with it to see exactly what it is. I noticed where the reservoir is when I was changing my fog lights. Quote Link to comment Share on other sites More sharing options...
