I plan on removing and cleaning my air intake arm and throttle body, and perhaps some other easy to access parts of my engine (92 ES) this weekend and I had a few questions. What should I use to clean inside these parts? WD-40 or similar solvent and clean rag, or are paper towels fine? What things should I not use? Any other tips would be appreciated, as this is my first time cleaning an engine. BTW, I do have a Hayne's Repair manual just to be sure.
I think there is a special throttle body cleaner you can buy & I would use rag's as opposed to paper towels to be safe & perhaps an old toothbrush. B)
:cheers:
TB cleaner or Carb cleaner. Just make sure it says "safe for O2 sensors" on the side of the can.
Don't use paper towels! :o you will leave paper bits.
use an old clean t-shirt or new shop towel.
steviej
use TB cleaner followed by brake clean to remove film
wd 40 will cause dirt to stick and plug the parts you have just cleaned
How do you go about detailing a 93 ES's engine bay? Any particular things you need to be concerned about spraying down your engine with water and engine cleaner?
check the detailing section
