rdlloyd Posted June 12, 2004 Posted June 12, 2004 My driver and Passenger doors close rather loud on my 96ES300, Does anyone know how to make the doors close quieter? its like almost a loud rattling slam when they are closed...since i dont have kids, the back passenger doors close nice ,crisp and quiet....n-e suggestions? ps:..how do you reduce wind noise thru the windows as well?
amf1932 Posted June 12, 2004 Posted June 12, 2004 You could try adjusting the door jam plate, up or down, in or out. You'll need a large phillips head screw driver to loosen it.
steviej Posted June 13, 2004 Posted June 13, 2004 new weather stripping around the door and door opening is a possibility. steviej
SKperformance Posted June 13, 2004 Posted June 13, 2004 the jam plates hardly move it is probably from someone leaning on them when open you need to get the hinges adjusted to get the door and window aligned properly, or you willl get lots of noise from air leaking on the highway
chadmg7 Posted June 14, 2004 Posted June 14, 2004 I have a small rattle noise that sounds like it's coming from my side mirror (on the passenger side) when I close that door. Is the mirror loose or is that unlikely?
Lexusfreak Posted June 14, 2004 Posted June 14, 2004 I suggest new weather stripping as well & making sure the two front doors are properly aligned.
