4 in total on each corner of the sunroof the rear wones are hard to get at but the front ones can be seen when open
use a can of wd 40 and then follow up with brake cleaner to remove the residue which the wd40 breaks down
i did mine in my civic now i get pools of water behind my front wheels when i wash the car
I take compressed air with a 14" piece of copper tube on the end of the blower nozzle, turn pressure down to 30 psi & just blow them out.
30 psi is still alot if it is real plugged you might blow the fittings off and end up with more water somewhere else with some nice rust
