Lexus ES300 Posted January 8, 2008 Share Posted January 8, 2008 Uuhhhh, another problem. OK, my 95 LS has a Lexus phone. Yesterday when I turned the radio on, voice was too low, even on maximum. After couple minuts, I heard a beep from phone and after that everythink was perfect. Today, same problem. Any adwice? Quote Link to comment Share on other sites More sharing options...
VMF Posted January 8, 2008 Share Posted January 8, 2008 can you recreate the problem? is the phone on or off? Quote Link to comment Share on other sites More sharing options...
nc211 Posted January 8, 2008 Share Posted January 8, 2008 Turn the phone off, if it's not used... Sounds like the little dial paddle on the steering wheel controls is stuck, which will mute your stereo in an attempt to dial the phone and use the speakerphone setup that over takes your stereo. Quote Link to comment Share on other sites More sharing options...
Lexus ES300 Posted January 8, 2008 Author Share Posted January 8, 2008 can you recreate the problem?is the phone on or off? No, the phone is off and I can't turn it on. While I drive it comes on with a beep and speakers start working. If I crank up the volume to maximum, the volume to th speakers is at a minimum, I can hear just a little voice and the quality is bad. Quote Link to comment Share on other sites More sharing options...
Lexus ES300 Posted January 9, 2008 Author Share Posted January 9, 2008 I found the problem. I just unplug the phone unit and now everything works fine. Quote Link to comment Share on other sites More sharing options...
92ls forhundo Posted January 13, 2008 Share Posted January 13, 2008 I found the problem.I just unplug the phone unit and now everything works fine. how and where did you unplug the phone? in the trunk? Quote Link to comment Share on other sites More sharing options...
drewkaree Posted February 24, 2008 Share Posted February 24, 2008 First-time poster. I've got a '96 with the same exact problem, and this is frustrating to read that you fixed it, but no idea HOW you fixed it, as I just bought the car YESTERDAY and have no idea where things might be in the car. Does anyone have a pic or at least a more detailed description other than "i just unplugged it" that might help? I'd REALLY like to just remove the phone entirely in order to be able to use that "tray" for storage, but it's more important for me to get my radio working again. Quote Link to comment Share on other sites More sharing options...
drewkaree Posted February 24, 2008 Share Posted February 24, 2008 Pertinent thread links would be appreciated too! :D Quote Link to comment Share on other sites More sharing options...
drewkaree Posted February 26, 2008 Share Posted February 26, 2008 Figured this out myself, and decided to take some pics so those who come up with the same problem might more easily fix it themselves as well. First step, remove the trunk mat. I've got a '96 LS, and found out I was targeting the area in the first pic. Second step, lift the covering carefully. There's a peg in the middle of the edge keeping it in place. Gently lift there (2nd pic) Third step, you should see the wiring you need to deal with. Looks something like the third pic. If you don't see it, check the other side of the trunk. Fourth step, disconnect the two white plugs. In the fourth pic, I've already finished. All you've got to do is simply disconnect them and reconnect them to the mating end of the OTHER plugs to complete the process. Quote Link to comment Share on other sites More sharing options...
