5V Source for Power Steering Pressure Sensor Switch
Hi,
I am getting a CEL for my Power steering Pressure Sensor switch. Tried to figure it out and found that it is not receiving 5V at the switch which I assume is due to a break on the wire. Can you please help and guide me to where i can get a 5V souce for the pressure sensor switch..
I am planing to disconnect the switch wires from the engine harness and connect them directly i.e. signal to the ecu, ground and 5V supply..
