Just had my nephew put a new timing belt kit on my 2002 Lexus SC430 - replaced valve cover gaskets and Spark Plug "O-Rings" with Lexus factory gasket kit. After install I'm getting a slight leak from the Spark Plug Boots that is running out around the boots and down the rail and onto the Driver Side Exhaust and it;s starting to smoke from hitting the exhaust聽pipe - what could be the cause? Thinking Worn Old Spark Plug Boots?聽 Please let me know what you guys think
All of these gaskets needed to be replaced, Not just the cover gaskets. Were they all replaced ?
Lexus SC430 (2003-2010) OEM Genuine VALVE COVER GASKETS SET
  • Like 1
Yes, All replaced with factory OEM O-Rings and Gaskets - looks like oil coming from between spark plug聽boot and 0"ring laying on rail then when car is in motion air blowing the oil along rail and onto the driver side manifold.
Sounds like one has to get back in there and find the culprit, Maybe there is a upside down gasket on a plug ??? I hope they are reversable...聽馃槥
  • 3 months later...
Recently had a similar issue: minor leak from valve cover gasket creating fumes. Found out that one quick fix would consist of simply tightening the nuts holding the cover. Somehow some of them became loose over the years creating this very minor leak. Either way replaced only one gasket and decided not to replace any other gasket upon inspecting the gaskets and noticing that they were in "excellent" shape. This to prevent complications as it happened here. Good luck, probably one of those may have dirt stuck creating a minor gap or so...
