James E Thompson Posted April 27, 2019 Posted April 27, 2019 My 92 Lexus has been a very reliable vehicle. Only major problems have been leak in a/c and power steering pump. Replaced one light bulb in dash over temperature gauge and now I see that the turn signal indicators in dash do not light or blink when all the exterior lighting for turn signal is working properly. Any suggestions on source of problem. Also noted that gear shift position in dash for N to D are not lighting.
James E Thompson Posted April 29, 2019 Author Posted April 29, 2019 There is a knob on the lower left side of dashboard which controls the light level in the dash. I might be turned off!
Matt3269 Posted April 29, 2019 Posted April 29, 2019 1 hour ago, James E Thompson said: There is a knob on the lower left side of dashboard which controls the light level in the dash. I might be turned off! If that was the case they would all be off. Probably just more bad bulbs. Most people replace all of them,when one fails the rest will be next
