PupilzSwag Posted February 20, 2017 Posted February 20, 2017 so these past few weeks I've about to $300 on batteries trying to figure out what the problem is why my car won't stay started I'm driving down the street and it just dies please help
TrevC Posted February 20, 2017 Posted February 20, 2017 Hi Maverick It's either battery quality, always stick to a reputable brand from a source you can trust....there have been several cases of counterfeit batteries around (can always tell by the weight - quantity of lead) or it is the alternator....not difficult to check with a multimeter. Should be producing around 14.4 - 14.8 volts with lights switched on. Any lower than 13.8 volts it's probably on it's way out. Also, very importantly, check the battery terminals are clean and tight ! Cheers Trevor
billydpowell Posted February 20, 2017 Posted February 20, 2017 dont they have any parts houses in Washington that will check your Alt for free ??? also remember to check for a GOOD GROUND 1
sha4000 Posted February 25, 2017 Posted February 25, 2017 Have you figured this out yet? If not, is there a check engine light on? Like billy said go to an autozone and they should be able check the condition of your battery and alternator for free. 1
vissine Posted September 17, 2017 Posted September 17, 2017 It happened to me before. First, the battery indicator lid up. Measured voltage between battery posts were 12.4 when car is off, and 11.8 when it runs. Raise the car up and measure the voltage at terminal B of the alternator when the car off, still 12.4 proving that there is continuity from the alternator to the battery and the 120 Amp fuse is still good, to be sure I check the continuity between the alternator terminal B and battery positive post anyway. It proves that the alternator was toasted. It takes 2 hours for me to replace the alternator and back on the road.
vissine Posted September 20, 2017 Posted September 20, 2017 One thing to remind, do not buy reman alternator. I went with new one with life time warranty. It should last for lifetime this time.
