Sunbeam Posted April 28, 2004 Share Posted April 28, 2004 I'm a bit confused as to whether the all wheel drive RX300 has all 3 of these. Can't tell from the owner's manual (supplement) whether the transfer case oil and the differential oil are separare units each requiring separate fluid changes for a total of 3 including the transmission itself. When I go in to have these changed, I'd like to appear reasonably knowledgeable. Thanks. Quote Link to comment Share on other sites More sharing options...
KevinK Posted May 1, 2004 Share Posted May 1, 2004 Anybody? :cries: Quote Link to comment Share on other sites More sharing options...
t3k81 Posted May 7, 2004 Share Posted May 7, 2004 how often do should we do oil changes to the transmission, and transfer case/differential oil? As to whether the last two oils are the same, I'd like to know also. where would they be located? in the rear of the car? Quote Link to comment Share on other sites More sharing options...
KevinK Posted May 8, 2004 Share Posted May 8, 2004 Anybody?????? I'll try to figure it out once I got my OEM service manual (from e-bay $130, on its way). Quote Link to comment Share on other sites More sharing options...
Sunbeam Posted May 8, 2004 Author Share Posted May 8, 2004 Thanks Kevin!!! Quote Link to comment Share on other sites More sharing options...
RX300 Steven Posted July 5, 2005 Share Posted July 5, 2005 I'm a bit confused as to whether the all wheel drive RX300 has all 3 of these.Can't tell from the owner's manual (supplement) whether the transfer case oil and the differential oil are separare units each requiring separate fluid changes for a total of 3 including the transmission itself. When I go in to have these changed, I'd like to appear reasonably knowledgeable. Thanks. ← I found on Amsoil's website the listing for all fluid types Question I have is, where is the drain/fill for the Transfer Case ? found everything else pretty easy so far. 2000 LEXUS RX300 3.0L 6-cyl VIN Code 1MZ-FE LUBRICANTS & FLUIDS Engine Oil Grade 1......API* SAE 5W-30 XL-7500 Synthetic Motor Oil Automatic Transmission.....TIV[2] Synthetic Automatic Transmission Fluid Differential, Rear .....GL-5 Above -18°C......90 SAE 75W-90 Synthetic Gear Lube Transfer Case,.....GL-5 SAE 75W-90 Synthetic Gear Lube 1. SAE 5W-30 is preferred. 2. TIV is ATF Type T-IV, Toyota part no. 08886-01705. CAPACITIES Engine, with filter..........5.0 quarts[1] Cooling System, Initial Fill..........9.5 quarts Automatic Transmission, 2WD Initial Fill..........3.7 quarts[2] Automatic Transmission, 4WD Initial Fill..........4.1 quarts[2] Automatic Transmission, Total Fill U140F..........9.8 quarts U140E..........8.8 quarts Differential, Rear..........1.9 pints Transfer Case,..........1.9 pints 1. After refill check oil level 2. With ENG automatic transmission operating temperature, shift through all gears. Check fluid level in PARK and add fluid as needed. TORQUES Oil Drain Plug.....33 ft-lbs Quote Link to comment Share on other sites More sharing options...
jbarhorst2 Posted July 5, 2005 Share Posted July 5, 2005 Tranny fluid is Toyota Type IV. Transfer case (next to transmission) takes Gear oil. Rear Differential (between rear wheels) takes the same gear oil as the transfer case. Tom. Quote Link to comment Share on other sites More sharing options...
TunedRX300 Posted July 5, 2005 Share Posted July 5, 2005 Transfer case has a separate drain plug facing the passenger side behind the tranny drain plug. Both can be opened with a 10mm Allen wrench. Fill up through the same tranny dip stick hole with Toyota Type IV ATF. Changing ATF Quote Link to comment Share on other sites More sharing options...
RX300 Steven Posted July 6, 2005 Share Posted July 6, 2005 Transfer case has a separate drain plug facing the passenger side behind the tranny drain plug. Both can be opened with a 10mm Allen wrench. Fill up through the same tranny dip stick hole with Toyota Type IV ATF.Changing ATF ← Looking at my owners manual for 2000 AWD, the transmission & front differential uses T-IV ATF and the transfer case uses gear oil. So what I'm searching for is someone that has changed the transfer case gear oil and can help with where the drain/fill is. The transmission as a drain on the bottom of the pan, and the front differential has a drain just behind the pan drain, but vertical on the side of the diff. Both transmission and front diff are filled thru the ATF dip-stick, but how the HE!! do you drain/fill the gear oil in the transfer case. I think the attached pic is the transfer case, it says 85W-90 GL5 which is gear oil. Quote Link to comment Share on other sites More sharing options...
TunedRX300 Posted July 7, 2005 Share Posted July 7, 2005 A lot of people use front differential and transfer case interchangably. What one should do is to fill whatever is drained. After you jack up the car, use a 1/2" drive, 15/16 socket, an long extension, and a breaker bar or torque wrench to loosen the blue fill plug facing the rear. Catch any gear oil leaking out with an oil pan. Use an open end 15/16 wrench to loosen the yellow 15/16 drain plug facing down (it is just couple inches down from the blue fill plug). Be careful not to strip it because Toyota did not leave enough space to allow my Craftsman combination wrench to securely latch on - just patiently angle the wrench in until you can get a reasonable hold. That is why spray PB Blaster or WD-40 to soak up both plugs 10 minutes before starting is helpful. Last, use a hand pump to fill after draining out oil gear oil. I used Mobil 1 75w90 synthetic gear oil since it is not easy to do the front differential (that is what I call it) fluid change. Need to rotate rear wheel by hand to make enough room for a 10mm Allen wrench to loosen the rear differential fill plug. Quote Link to comment Share on other sites More sharing options...
