Lexicon17 Posted January 1, 2017 Share Posted January 1, 2017 RX 350, 2GR-FE engine, 121k miles. Engine died while cruising on highway. A very dangerous situation as you lose steering and brakes. Managed to pull over and tried a re-start. Engine starts fine but stall within 3 seconds. I noticed engine will not stall if A/C is turned off. Has anyone experienced the same issue. I would appreciate it very much what the issue and the fix. Thanks in advance for your time. Happy New Year To All. Quote Link to comment Share on other sites More sharing options...
RX400h Posted January 3, 2017 Share Posted January 3, 2017 I suspect that either the AC alternator or a pulley is bad, or an idle control module has failed. Thankfully, you can still drive your vehicle while the issue is resolved. Quote Link to comment Share on other sites More sharing options...
Lexicon17 Posted January 5, 2017 Author Share Posted January 5, 2017 Thanks "RX400h" for your reply.Spent most of yesterday at the dealership for diagnostics. Service Consultant says compressor is seized. What he meant I think is compressor clutch. He cannot however explain why engine stall. Job estimate is $2,200. for new compressor and receiver drier, OUCH! Quote Link to comment Share on other sites More sharing options...
RX400h Posted January 5, 2017 Share Posted January 5, 2017 Wow! You might want to ask a Toyota dealership or trusted local shop what they would charge. The engine stalls because there may be too much clutch torque resistance when the AC is turned on. By the way, Happy New Year, as well. Quote Link to comment Share on other sites More sharing options...
lenore Posted January 5, 2017 Share Posted January 5, 2017 Either that or the the belt broke and wrapped around the crankshaft. Quote Link to comment Share on other sites More sharing options...
lenore Posted January 5, 2017 Share Posted January 5, 2017 The compressor is less than $300 from RockAuto. I would pull vehicle and have an independent replace it. Quote Link to comment Share on other sites More sharing options...
