jeharter Posted July 18, 2015 Share Posted July 18, 2015 The dual temp control blows warmer on driver side when in AC mode. Is their a thermostat or something like it that regulates cabin temps. Just started doing this. Car has 155,000 miles. Appreciate any thoughts Quote Link to comment Share on other sites More sharing options...
pj8708 Posted July 18, 2015 Share Posted July 18, 2015 Hi Jim, There are air direction vanes within the housing that controls the amount of cold and hot air as called for by the thermostat you set. It could be that one of the servos that control the opening and closing of the vanes is bad. I'm not betting the farm on this but it's one thing to consider. Paul 1 Quote Link to comment Share on other sites More sharing options...
gbhrps Posted July 19, 2015 Share Posted July 19, 2015 jeharter, I agree with Paul's assesment. You have a blend door or its actuator motor that is broken or stalled in one position, read "very expensive to fix, if you go to a Lexus dealership". The darn thing is hidden way up in behind the dash and is awkward as he** to get at, which equals time = labour dollars. As a DIY fix it requires the pages from the FSM (factory service manual) for the correct diagnostics and the step by step to get at the motor/blend door or its motor. In my case I have 6 vehicles I can drive while the Lexus is tied up, am retired, have the tools, and have been a backyard mechanic for 45 years, so I'd tackle it in a heart beat. Not everyone is so lucky. If you have a good independent mechanic or are a fairly competent mechanic yourself, go for it. Parts would be best found in a junkyard, if you have the time. Good Luck! 1 Quote Link to comment Share on other sites More sharing options...
jeharter Posted July 29, 2015 Author Share Posted July 29, 2015 Thanks to all. Before tackling the job I threw a set of gauges on the air conditioner and found the AC to be low on gas. Charged the system and brought it back to normal. This $12 fix saved me a days labor or $1,700 in repairs at the dealer. Quote Link to comment Share on other sites More sharing options...
gbhrps Posted July 29, 2015 Share Posted July 29, 2015 Great save! Quote Link to comment Share on other sites More sharing options...
VBdenny Posted July 30, 2015 Share Posted July 30, 2015 Yes but the gas went somewhere. You might throw some indicator dye in and check for a small leak. Of course R-134a is cheaper than leak repairs and for small ones, I just recharge every few years. My friends 1993 Camry wagon wasn't blowing cold and he was quoted a huge amount to fix. I hooked up the old well worn R-12 gauges and my 30lb. tank and charged it up 3 years ago. Still ice cold and the cost? Nothing. All hope is not lost. Quote Link to comment Share on other sites More sharing options...
sadclown Posted August 13, 2015 Share Posted August 13, 2015 I have an impression that this issue may be caused by the HVAC system. Have it checked. Quote Link to comment Share on other sites More sharing options...
jeharter Posted August 13, 2015 Author Share Posted August 13, 2015 You were right. Before tackling the job I threw a set of gauges on the air conditioner and found the AC to be low on gas. Charged the system and brought it back to normal. This $12 fix saved me a days labor or $1,700 in repairs at the dealer. Quote Link to comment Share on other sites More sharing options...
