ovonic Posted July 11, 2015 Share Posted July 11, 2015 own a 2004 rx330 noticed the transmission felt like the esc was stuck on a month later started leaking trans fluid like crazy from passenger side. any ideas Quote Link to comment Share on other sites More sharing options...
lenore Posted July 12, 2015 Share Posted July 12, 2015 Could be the axle shaft seal broke loose. Look under car and see if the fluid is coming from the right side cv axle shaft where the shaft goes into the transmission. Wouldn't suggest driving it that way if it is leaking bad. Other thing it could be is the axle became unclipped in the transmission and is leaking thru that same seal. Quote Link to comment Share on other sites More sharing options...
ovonic Posted July 12, 2015 Author Share Posted July 12, 2015 thanks for the reply i am going to check that out. Quote Link to comment Share on other sites More sharing options...
