2 Lexus OKC Posted March 6, 2015 Share Posted March 6, 2015 I am new to the Lexus Owners Club. My rx300 is making a noise in the front right wheel well when i go over a bump. Im not sure exactly what it is but does anyone have any suggestions on what it might be. THank you Quote Link to comment Share on other sites More sharing options...
VBdenny Posted March 6, 2015 Share Posted March 6, 2015 Hey Corey, Very likely a suspension issue. There are several things that can go bump, none of which are desirable. What I would do was take the car someplace where they do alignments and have them check. Without a doubt they will tell you there is something wrong. I do know that front right suspension parts often take more abuse than the driver side and often fail first. Sorry you are having problems but welcome to LOC anyway. Hopefully you will be able to learn a lot about your car and how to keep it operating great without breaking the bank. Denny Quote Link to comment Share on other sites More sharing options...
2 Lexus OKC Posted March 6, 2015 Author Share Posted March 6, 2015 AWESOME. I PLAN TO TAKE IT IN TO A PLACE WHEN I PUT NEW RIMS ON IT THIS MONTH OR SO. THANKS FOR YOUR HELP Quote Link to comment Share on other sites More sharing options...
lenore Posted March 7, 2015 Share Posted March 7, 2015 Could be the stabilizer bar link. Quote Link to comment Share on other sites More sharing options...
fernandolpa Posted April 18, 2015 Share Posted April 18, 2015 I have the same issue in my 2001 AWD from many long time. I guess is something related with the brakes, as if I push the brakes slightly over the bumps noise stops. I spoke with Lexus dealer but they have no idea. I guess is something with the brake pads and some missing small piece. I tell you this because if I put some cooper grease behind the pad the noise despairs. If you find the final reason let me know, it has been many years with this noise already. In Spain we have exhaustive yearly inspections (brakes, suspensions, struts, stabilizers...and the car is perfect year by year with no complaints at all in the inspection, so I guess is nothing related with all these parts. Quote Link to comment Share on other sites More sharing options...
VBdenny Posted April 18, 2015 Share Posted April 18, 2015 Upon hearing the suspicion about the brakes, I had a thought. Having done many brakes on these cars I do know there is a wishbone spring that must be installed in the pads to keep them from rattling. Many aftermarket brake "Specials" use junk pads and just discard the plates and wishbone springs. I'd start by taking a look at that. Take off the tire and you can either see them, or not. Just a thought passing through. 1 Quote Link to comment Share on other sites More sharing options...
fernandolpa Posted October 6, 2016 Share Posted October 6, 2016 Ok, finally I know from where this noise comes. It is recommended by Lexus to replace the brakes pads clips at the same time pads are changed. Almost anybody does it, even Lexus dealers. So after she pads changes, these clips does not longer keep the pad on place, making the rattle sound on bad roads. Replacing the clips is the solution. Part number for a 2001 RX300 is 0494733120 Hope is the same for you Quote Link to comment Share on other sites More sharing options...
fernandolpa Posted October 15, 2016 Share Posted October 15, 2016 Last update and problem solved. After installing the clips above, problem is gone. Quote Link to comment Share on other sites More sharing options...
