Need some help here !!
I can't find the transmission fluid dipstick on my 2006 LS430.
Is this a sealed unit?
How do you check the fluid level?
Thanks in advance for any guidance !!
on the 2001 to 2006 transmission its located next to the engine oil dipstick (yellow) and the transmission one is red.
  • 4 weeks later...
There is no dipstick for the AT. The AT is so called "lifetime lubricated".
Adding or draining fluid to AT is done from below, a royal pain too......
  • Like 1
I have a 2003...the tranny dipstick is mounted low alongside the oil dipstick. It has a retention clip, but can be removed and checked as normal. It is labeled as not requiring service under normal driving. LF.
  • 3 weeks later...
01-03 has a dip stick
04-06 is sealed (Still has drain, overflow, and fill plugs on the transmission itself)
