Does anybody have directions as to how to replace the light bulb in the ignition ring?
Yes, learn how to do a search for your needs, and you can help others like you were just helped...
Just a little advice, if you are replacing the bulb with an LED make sure the quality is good. Reason I mention it is I fitted cheap ones in mine along with the footwell ones and it damaged the integration relay way under the dash.
If you are using a conventional lamp don't worry.
THANKS...Richard and Steve! Replacement was a snap. Steve...your car looks tops...was trying to blow it up so I could see it better but didn't have any luck. Chrome lettering and emblems would look really good on your color car. I'm in the process of having my lettering and emblems redone after a new burgundy paint job. Added Sirius radio so I can listen to the 50's 60's and 70's. Paid 5000 for it 10 years ago and have only replaced one alternator. Rides and looks excellent. What a car! Wish I could have had it as a young man in 68 upon returning from Nam.
