skyview Posted March 3, 2004 Posted March 3, 2004 Seeking an OBD tool for 1995 LS400. Can be hand held, PDA, or laptop driven. Thanks In Advance
SKperformance Posted March 3, 2004 Posted March 3, 2004 i am going to move this to the gnereal maintance but an obd 2 scanner should work on your 95 not an obd 1 any scanner under $1000 will do the exact same thing,pulls a code and can reset the light nothign else,will not help diagnosis nor look at any other system codes for abs or srs.
blake918 Posted March 4, 2004 Posted March 4, 2004 Is it possible to get the scan tool that Lexus shows in the factory repair manual?? It seems like the Lexus scanner can pull info from every componet in the car! Even if someone were to find these scanners, I'd bet they cost a fortune!
blake918 Posted March 5, 2004 Posted March 5, 2004 Geez $15 grand for a scanner :o ? Is that thing turbo charged?
SKperformance Posted March 5, 2004 Posted March 5, 2004 When you are in buisness knowledge is power .Only the elite can afford the otc scanner that is programmed for lexus only. It will service and display almost nay parameter for the car to diagnoise quickly any problem with a good tech. A snap on scanner starts at $5000 and you still need to buy the keys ,plugs and adapters for different vehicles.
LucasLutian Posted June 11, 2013 Posted June 11, 2013 in my point of views and opinion is it possible to get the check out device that Lincoln reveals in the manufacturer fix manual?? It seems like the Lincoln scanning device can take details from every component in the car! Even if someone were to discover these readers, I'd bet they price a fortune! . . . baltimore car service | baltimore limousine service | limo service baltimore
