Has anyone had a leak in their power steering pump? The pump seems good but it's leaking and all the lines seem fine but it must be leaking around the pully, bolts on or the big bottom line. Any ideas?
What needs to come off to get this thing off?
this is a common problem. don't let it go too long as it leaks on the alternator and can fry it. I had to replace both the PS pump and the alt.
I had the dealer do it. Not cheap. If you are so inclined, look around this forum--there is probably info on how to change it yourself.
i think its held on by three bolts and a nut. it should be fairly simple and stright forward to replace
your gonna have to go from underneath to take the pump out. first take out the alt and then the pump. you can see from there what you have to do to take the pump out.
