J Random User Posted July 17, 2011 Share Posted July 17, 2011 I'll probably get Centric C-Tek rotors. (They're like the Premium rotors but without the black E-coating finish) For pads, I'm leaning towards StopTech Street Performance but also considering Hawk HPS and Wagner ThermoQuiet. Anybody have experience with any of these pads? Quote Link to comment Share on other sites More sharing options...
TA in KC Posted July 17, 2011 Share Posted July 17, 2011 I've had mostly lousy experiences with aftermarket brake pads and prefer to stick with OEM Toyota ones. Sewell Lexus is a good place to purchase them- with the forum discount, the pads for my 98 LS cost about the same as aftermarket ones. I tried Wagner ThermoQuiet pads on my previous 92 LS a couple of times. Maybe I wasn't doing something correctly, but with them installed the brakes always made a squealing noise that I couldn't get to go away. That, and on two different occasions the ceramic elements of the pad became separated, fell off while driving and caused damage to the rotor from the metal to metal contact. The second time it happened I went back to OEM Toyota pads and had no further problems. Why not try having your rotors resurfaced before replacing them? Unless they are very worn, that should be enough and would be much less expensive than replacement. Quote Link to comment Share on other sites More sharing options...
J Random User Posted July 18, 2011 Author Share Posted July 18, 2011 Well my car has over 180k on it, and new rotors are only about $20 each Quote Link to comment Share on other sites More sharing options...
lenore Posted July 18, 2011 Share Posted July 18, 2011 I have had great luck with the Akebono pads...Seem to last every bit a long as the OEM.... Quote Link to comment Share on other sites More sharing options...
J Random User Posted July 24, 2011 Author Share Posted July 24, 2011 Thanks for your help everybody! I found a sweet deal on Axxis Deluxe Plus (OE pad material), so I ended up getting those. About $30 for both front and rear (they usually go for at least twice that much, if not more!) Quote Link to comment Share on other sites More sharing options...
DEATH_AWAITS_YOU Posted July 25, 2011 Share Posted July 25, 2011 I've had mostly lousy experiences with aftermarket brake pads and prefer to stick with OEM Toyota ones. Sewell Lexus is a good place to purchase them- with the forum discount, the pads for my 98 LS cost about the same as aftermarket ones. I tried Wagner ThermoQuiet pads on my previous 92 LS a couple of times. Maybe I wasn't doing something correctly, but with them installed the brakes always made a squealing noise that I couldn't get to go away. That, and on two different occasions the ceramic elements of the pad became separated, fell off while driving and caused damage to the rotor from the metal to metal contact. The second time it happened I went back to OEM Toyota pads and had no further problems. Why not try having your rotors resurfaced before replacing them? Unless they are very worn, that should be enough and would be much less expensive than replacement. Good call, TA. Nothing works better than OEM brake pads on these cars. Squeeling brakes would drive me up a wall! Quote Link to comment Share on other sites More sharing options...
