Won't Idle When Cold (Stalls)
jtbel
I am having to give it gas until the engine warms up. This is only when engine is cold. If not the engine will shut off. What parts can be attributed to this problem? I already cleaned the iacv as best I could. How do you test it to see if it still works? Other than the iacv, what part could be at fault? Thanks
Check the engine coolant temperature sensor,if it's faulty it may be telling the ECU the engine is nice and warm when it is in fact cold so the fueling will be incorrect causing the stalling.
Check for vacuum leak on intake ducting. If a duct is cracked or not fitted properly it will pass air that won't be detected by the MAF sensor and could mess up EFI trimming by ECU.
You cleaned IACV but did you clean Throttle body too? If it is caked up with carbon that could add problems too.
