pberku Posted May 9, 2010 Share Posted May 9, 2010 I have a 2001 Lexus ES300 with 75,000 Miles, All was well until I decided to do a drain and refill. The garage drained my ATF fluid, (3.5 Liter of a total capacity of 8.25 Liters), and re-filled it with 3.5 Liters of Dexoil III. I know that my car is only supposed to use Toyotal ATF T-IV and not Dexoil III. I realized his mistake only the next day. I know that flashing the whole thing is not a good idea, and that draining and refilling again will only get some of the Dexron out but not all. So now what do I do? Thanks, Phillip Quote Link to comment Share on other sites More sharing options...
lenore Posted May 9, 2010 Share Posted May 9, 2010 You could do a fluid exhange instead of a flush...The Car is left running and the tranny pump flushed the fluid naturally. However, I would opt for a drain and fill without filter, drive a few days and do it again with either Toyota Type IV or Mobil Tranny fluid which is compatable. Quote Link to comment Share on other sites More sharing options...
dcfish Posted May 9, 2010 Share Posted May 9, 2010 You could do a fluid exhange instead of a flush...The Car is left running and the tranny pump flushed the fluid naturally. However, I would opt for a drain and fill without filter, drive a few days and do it again with either Toyota Type IV or Mobil Tranny fluid which is compatable. I concur with Lenore Quote Link to comment Share on other sites More sharing options...
pberku Posted May 9, 2010 Author Share Posted May 9, 2010 You could do a fluid exhange instead of a flush...The Car is left running and the tranny pump flushed the fluid naturally. However, I would opt for a drain and fill without filter, drive a few days and do it again with either Toyota Type IV or Mobil Tranny fluid which is compatable. Its too late now, as I had the Filter changed at the same time that the incident happened, but am curious as to why you are recommending not to change the filter? Phil Quote Link to comment Share on other sites More sharing options...
