pacsail Posted April 29, 2010 Share Posted April 29, 2010 Six month ago I got a CEL code P0306 which I traced to a defective coil in Cyl. # 6. Installed new coil, cleared code, and things were fine until 2 month later code P0306 & now code P1325 reappeared. Accompanied by the jerking above 40MPH and not shifting into high gear (TRAC light illuminates also). Just by reading and clearing these codes took care of problem. Now the CEL and same codes occur every 3-4 weeks, which I clear with my code reader. Otherwise the car (175K miles) runs perfect. The CEL, when it decides to reappear, only comes on at engine start, both cold and warm starts. Other than keeping my code reader in the glove box, what else can I do? Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted May 1, 2010 Share Posted May 1, 2010 Since both codes are for missfire, have you checked the spark plug? Also check compression, to small of a gap on one of the valves will cause lower compressions and a missfire. There could also be a issue with the injector, you could try swapping with with #4 and see if the missfire moves. Quote Link to comment Share on other sites More sharing options...
pacsail Posted May 11, 2010 Author Share Posted May 11, 2010 Spark plug on #6 had huge gap (> .070"), so I installed new plug. Wait and see if problem persists. Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
lenore Posted May 12, 2010 Share Posted May 12, 2010 The gap should not have been off. Are you using Denso or NGK iridium Plugs (original equipment)? If they are Bosch get them out of there...(Garbage in this motor) Quote Link to comment Share on other sites More sharing options...
pacsail Posted September 20, 2010 Author Share Posted September 20, 2010 Well, the problem has started again. Code P1325. Usually cleared with code reader and/or disconnecting battery for 1 hr. Cleaned MAF last week - the intermitent problem keeps popping up. Anyone have ideas? Quote Link to comment Share on other sites More sharing options...
lexis lexus Posted September 21, 2010 Share Posted September 21, 2010 Intermittent codes suggest intermittent events. Misfires caused by what? You name it from rings, valves, plugs, or.... flakey wiring. Seeing how bad the wiring is in and around the heads in the mk 2 es300's I've been dissecting lately, I'd look to this external cause. LL Quote Link to comment Share on other sites More sharing options...
yeskay Posted September 21, 2010 Share Posted September 21, 2010 http://ww2.justanswer.com/uploads/snd27613/2008-10-22_165255_p1300.pdf Quote Link to comment Share on other sites More sharing options...
