I just ordered an Equus OBD I code reader and then realized the application sheet only shows it for models through 1993. The emmisions sticker does not say OBD II compliant. I found a site that says in 1994 Lexus began using OBD II, but they were not fully compliant. Is there a specific reader for the 94 and 95? Will an OBD II work, but not fully?
update:
i called equus the same night and they cancelled my obd i scanner order. found the obd ii scanner from midway auto supply for $119 and free shipping. got it today and it works great.
the check engine light went out yesterday, but the reader shows the only stored code as P0135 - 02 sensor heater circuit malfunction (bank 1 sensor 1). i hardly ever need the heater in south florida so i am happy this was the only code.
i love this reader. thanks again for the help.
It is saying the oxygen sensor is defective for the engine,not the hvac system.
So you are running rich right now and wasting gas until you fix it.
I have a 1994 Lexus ES300
If it has this engine in it will this Reader work for mine as well?
Where is the interface located?
And where is the engine model located?
Found that I have the 1mz-fe Engine, where is the interface for reading the plugging in the code reader?
And is there some that work with laptop & Software you would recommend?
Pull the fuse panel cover inside the car below the mirror controls, and you will see the plug(it looks like something you'd see on a computer) next to the fuses. If you can't find it, I'll snap a pic for you.
:cheers:
It is to the right of the fuses behind the fuse cover which is to the left of the steering wheel.
you are right it is a 1mz-fe engine and obd2
there is also another data connection on the top of the intake maniold of the engine on the right side
