arcticsilver Posted January 20, 2004 Share Posted January 20, 2004 Hi I just got a 92 LS400 with 87k on the clock, my rad fan has one fin missing and is very stiff. When i rev the engine up it roars very loudly, so im guessing the hydraulic/viscous fan is not releasing. I live in the uk, do you think i can remove the fan and rely on the single electric fan or invest in either a new viscous fan or and electric one... bear in mind uk temp is on average 20c :) any help much appreciated Martin UK LS400 driver Quote Link to comment Share on other sites More sharing options...
gaknut Posted January 21, 2004 Share Posted January 21, 2004 Climate has little to do with engine temp, so would recommend replacing entire unit (fan and clutch). Missing blade should be cause for concern. Why is it missing? A missing blade would cause the fan to be severely out of balance. Several sensors on this engine rely on proper engine temp to adjust fuel, timing, etc. Just too critical an item to attempt a shortcut. Quote Link to comment Share on other sites More sharing options...
arcticsilver Posted January 21, 2004 Author Share Posted January 21, 2004 I was wondering why one blade was missing... but never found out. Your right it does make a vibration through the car thats one of the main reasons for taking it of.. priced replacement in UK and it works out at around $500 just for the fan and viscous clutch!!! so may convert to and electric fan if its not to big a job! Quote Link to comment Share on other sites More sharing options...
VBdenny Posted January 21, 2004 Share Posted January 21, 2004 Before I spent $500 to replace one of the two electric fans, I'd remove the broken fan and drive the car. I feel the two fans are probably just overkill. Even here in southeast Virginia in the summer my engine temperature doesn't change much and I had hardly ever had the fans turn on anyway. Then I would keep looking around and see if I could fin a used fan. I saw someone had a post about wrecking their LS, so you might drop them a note and see if they are repairing or parting out, You also might try www.car-parts.com sometimes they have stuff like this. Quote Link to comment Share on other sites More sharing options...
VMF Posted January 21, 2004 Share Posted January 21, 2004 2 external fans are for the AC system and not for the engine while internal fan is specifiaclly for the engine radiator. it has a temperature clutch wich controls fans revolutions. this fan is vital for for the engine and should be replaced ASAP otherwise you are riskin to shorten life of your engine. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted January 21, 2004 Share Posted January 21, 2004 With U.K. models having only one electric fan and with last summer's all time record high U.K. temperature of around 37c, I'd also recommend you get your fan fixed. Gosh, I was in the U.K. in 1990 during the previous all time record high temperature and I remember Kew Gardens looking a bit like the Arizona desert. If it stayed around 20c all year you might be able to get away without having the viscous fan but gosh it can get rather warm there in an average summer. Quote Link to comment Share on other sites More sharing options...
K9crew Posted January 21, 2004 Share Posted January 21, 2004 Martin, If I were in your position I'd install an electric fan as well ... I've never been a fan (no pun intended) of the viscous clutch arrangement. There are numerous options available from places like Summit Racing and you'll pay a lot less than $500. You could possibly free up a few horsepower as well!! http://store.summitracing.com/section.asp?d=5&s=93 Be Cool and Perma-Cool make good products. P.S. Welcome to the club ... it's always good to see a fellow "Limey" on the board! :) Quote Link to comment Share on other sites More sharing options...
arcticsilver Posted January 21, 2004 Author Share Posted January 21, 2004 well guys it took the fan of today and wow what a difference it made... the car is... silent.. and power??? I really feels like I got a new engine in there. When i got to the viscous clutch it was a wobbly as my gran after 10 jack d's :) so off it came. I am goin to use electric fan... the UK car has only one fan on the front of the rad!? Running round the temp gauge is just below halfway and never budges... on uk forum it seems a few have removed fan n using just the 1 outer fan?! PS love the forum! Quote Link to comment Share on other sites More sharing options...
UCF3 Posted January 22, 2004 Share Posted January 22, 2004 Dam. I was trying to sell a fan clutch last month. The manufacturer sent me a new one when I asked for a Fan Bracket. I still have the other one--nothing's wrong with it. I'm a little lost. Which Fan is missing the blade, the AC/Radiator fans or the engine fan? Quote Link to comment Share on other sites More sharing options...
arcticsilver Posted January 22, 2004 Author Share Posted January 22, 2004 UCF3 Its the engine fan that is missing a blade... and the fan clutch had also broken... I can wiggle it in all sorts of directions LOL If u sell the clutch give me a shout may be interested!!! Quote Link to comment Share on other sites More sharing options...
arcticsilver Posted January 23, 2004 Author Share Posted January 23, 2004 i removed the engine fan... the UK car must be different to the US one as ours only has a single electric fan that comes turns on when the engine temp gets halfway up the gauge?! Quote Link to comment Share on other sites More sharing options...
