Seafoam On 93 Ls 400
silvermistLS
i pulled the break booster hose off the back of the intake manifold and used a longer piece of bendable tubing. I used about a third to half of a can and that was plenty. Split the rest between the oil and gas. Just make sure you dont put more than a few hundred mile on the oil before you change it after you add the seafoam. Hope that helps. It helped my 93 alot.
