jpilk99 Posted August 8, 2009 Share Posted August 8, 2009 Hi folks. I've seen pdf's and pictures before on how to take off the couple of pastic covers in the center console & shifter to be able to get down underneath to the audio wiring. I'm selling car and need to remove the DICE ipod adapter that's plugged in by the CD wiring. Any help is appreicated. Thanks, Jay Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted August 8, 2009 Share Posted August 8, 2009 Here are instructions for the LS430 on Pro.Fit's website: http://www.pro-fit-intl.com/Adobe/MV-50-03-L-p18.pdf The instructions are for installing one of their brackets but maybe it will be enough for you. Quote Link to comment Share on other sites More sharing options...
jpilk99 Posted August 9, 2009 Author Share Posted August 9, 2009 Here are instructions for the LS430 on Pro.Fit's website: http://www.pro-fit-intl.com/Adobe/MV-50-03-L-p18.pdfThe instructions are for installing one of their brackets but maybe it will be enough for you. -------------- Thanks, but, I actually need help just getting the plastic cosmetic covers off of the shifter base and then that whole plastic cover underneath the shifter base - where the ashtray sits into. Any ideas? I've seen nice step-by-step photos but ofcourse can't find em' now :-). Jay Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted August 10, 2009 Share Posted August 10, 2009 OK, then take a look at the attached PDF. LS430_Instrument_panel_removal.pdf Quote Link to comment Share on other sites More sharing options...
jpilk99 Posted August 10, 2009 Author Share Posted August 10, 2009 OK, then take a look at the attached PDF. ---- This helps! Thanks!!! Quote Link to comment Share on other sites More sharing options...
ford212.809 Posted August 17, 2009 Share Posted August 17, 2009 Here are instructions for the LS430 on Pro.Fit's website: http://www.pro-fit-intl.com/Adobe/MV-50-03-L-p18.pdfThe instructions are for installing one of their brackets but maybe it will be enough for you. -------------- Thanks, but, I actually need help just getting the plastic cosmetic covers off of the shifter base and then that whole plastic cover underneath the shifter base - where the ashtray sits into. Any ideas? I've seen nice step-by-step photos but ofcourse can't find em' now :-). Jay Do these same instructions apply to a 1999 LS? If not, can someone post istructions for me? Much appreciated....... Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted August 17, 2009 Share Posted August 17, 2009 Its probably easer on a 95-98 LS400. The provide website has instructions for the LS400 too: http://www.pro-fit-intl.com/Adobe/MV-50-03-L-p19.pdf I've popped the radio in my 00 LS400 out a number of times -- takes about five minutes once you get the hang of it. After you remove the center air vents and the wood console/ashtray assembly, only four 10 mm bolts hold the radio/HVAC controls in place. Quote Link to comment Share on other sites More sharing options...
ford212.809 Posted August 17, 2009 Share Posted August 17, 2009 Thanks for the reply - HOWEVER, I need the instructions for the removal of the shifter trim ONLY, if anyone can help......Thanks Quote Link to comment Share on other sites More sharing options...
