weidmark Posted July 5, 2009 Share Posted July 5, 2009 so a few weeks ago i turned on the sound in my car and all of a sudden i heard a static sound coming from my subwoofer then a popping sound... then no more sound came from the sub. i have no experience with this stuff so i thought it was just a blown sub... today i took out the sub and tested it and it was still working just fine. so now m assuming it was the amp... does this mean the amp is blown and needs to be replaced? or is it just like a blown fuse or something? also where is the amp located on a 92 ls400 with the nak system? i was told under the passenger seat... but i looked there and didnt see it. Thanks Quote Link to comment Share on other sites More sharing options...
Quack11 Posted July 6, 2009 Share Posted July 6, 2009 so a few weeks ago i turned on the sound in my car and all of a sudden i heard a static sound coming from my subwoofer then a popping sound... then no more sound came from the sub. i have no experience with this stuff so i thought it was just a blown sub... today i took out the sub and tested it and it was still working just fine. so now m assuming it was the amp... does this mean the amp is blown and needs to be replaced? or is it just like a blown fuse or something? also where is the amp located on a 92 ls400 with the nak system? i was told under the passenger seat... but i looked there and didnt see it.Thanks I've got the 91 LS400 and the amp is located in the trunk. Facing the trunk, it is directly behind the left aft passenger seat back and behind the carpeting. Make sure your other speakers work fine, check the balance, FWD, AFT, left and right operation. If all your speakers work the you will want to focus on the amp but make sure it is getting power and the harness from the amp to the radio is intact. I have the Panasonic system so I am not sure if the setup is the same. Good luck and keep the forum posted. Quote Link to comment Share on other sites More sharing options...
lexfourcam Posted July 7, 2009 Share Posted July 7, 2009 check the fuses for the radio, one of them could have blown, but if thats not the case it sounds like the amp. does the radio still come on? Quote Link to comment Share on other sites More sharing options...
