Problem With Car Lighter
tompkinsmt
For some reason the car lighter in my car will not work. Any idea oh now i can fix this? or maybe a tutorial about how to fix it? i have an XM radio and it wll not work if the lighter does not work. Any ideas will help. Thank you.
this is not so much a problem of not working.. but when i use it, it gets hot then flies about an inch into the air and out onto the console/floor. anyone experienced this problem and maby have an easy fix? its very dangerous
check fuse
ive checked the fuse. But when you look down the wire there seems to be anouther longer fuse or something, hard to see since there seems to be a plastic case over it and i dont know if that has anything to do with it. But ill check it out, thank you all for answering.
