was.happy Posted June 8, 2009 Share Posted June 8, 2009 I have a 1997 ES 300 with 102,000 miles on in. Several times in the last few months I have turned the key to start the car and nothing happens - dead silence. I can turn it a second time and it starts perfectly (sometimes it takes a third try). I don't think the problem is the battery since it is relatively new (installed 10 months ago). Plus, when the engine does start, it turns over very strongly. I wonder if my problem is a bad ignition switch (or one that is in the process of going bad). I wasn't that concerned since this was only a minor annoyance that occurred perhaps once every two months. However, last week it occurred several days in a row. I'm afraid the condition is deteriorating and I don't want to be left stranded somewhere. Any comments or advice? Quote Link to comment Share on other sites More sharing options...
dcfish Posted June 8, 2009 Share Posted June 8, 2009 Starter contacts ? Does your key fit tightly in the ignition? or is there any play ? Double check the battery terminals so they are very clean and tight. Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted June 8, 2009 Share Posted June 8, 2009 If it starts strong on the next try, then it is not the battery. Next time it happens try putting the trans into neutral. you could have a switch going bad. Quote Link to comment Share on other sites More sharing options...
amf1932 Posted June 8, 2009 Share Posted June 8, 2009 Could be a defective ignition switch. Quote Link to comment Share on other sites More sharing options...
subydude999 Posted January 26, 2010 Share Posted January 26, 2010 Could be a defective ignition switch. Did you ever find the solution to the problem, if so, what did you do to fix it? I have the exact same problem in my 95 ES 300 and am guessing it is caused by the starter solenoid contacts failing. Quote Link to comment Share on other sites More sharing options...
