Quixtar Posted May 28, 2009 Share Posted May 28, 2009 My car sometime has a check engine light come under the dash and the car acceleration kinda runs slow. One mechanic said he need to replace knock sensors(1000 dollars job) and other mechanic said he can't find out whats wrong with it you know!! So I confused Don't know whats going on? Any help? Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted May 28, 2009 Share Posted May 28, 2009 Did one or more error codes indicate a knock sensor problem? What are the error codes that accompany the check engine light? Quote Link to comment Share on other sites More sharing options...
Quixtar Posted May 28, 2009 Author Share Posted May 28, 2009 Did one or more error codes indicate a knock sensor problem? What are the error codes that accompany the check engine light? One Mechanic says its the knock sensor!! Quote Link to comment Share on other sites More sharing options...
Quixtar Posted May 28, 2009 Author Share Posted May 28, 2009 Did one or more error codes indicate a knock sensor problem? What are the error codes that accompany the check engine light? One Mechanic says its the knock sensor!! Thats what he said the code said Quote Link to comment Share on other sites More sharing options...
nc211 Posted May 28, 2009 Share Posted May 28, 2009 Get the actual code number and post it up here, or google it, to verify what he is saying. The reader won't "say" what is wrong, it will give a series of numbers that you then use to look up in the mechanic's manual for the car. You want to make sure he's telling you the truth, and verify the code number. Quote Link to comment Share on other sites More sharing options...
Quixtar Posted June 11, 2009 Author Share Posted June 11, 2009 Get the actual code number and post it up here, or google it, to verify what he is saying. The reader won't "say" what is wrong, it will give a series of numbers that you then use to look up in the mechanic's manual for the car. You want to make sure he's telling you the truth, and verify the code number. How do you find a code Quote Link to comment Share on other sites More sharing options...
desperado2 Posted June 11, 2009 Share Posted June 11, 2009 take it to autozone they would do it for free... and also tell you what it means Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted June 11, 2009 Share Posted June 11, 2009 Yes the same way we told you back on may 8, still having the same problem. Still have not tried anything, but vague questions? Quote Link to comment Share on other sites More sharing options...
