1992 Lexus Ls400 Car Is On Jack Stands When The Car Is Neutral And On
sherlockshah
Sounds like you need to check your trunk wiring harness.
No it's not normal for your wheels to be turning when the car is in neutral.
I checked it , the one on the drivers side, i opened up the whole thing there are no cuts or lose connections, :( I am suppose to look at the one that goes under the plastic cover that lines up with the trunk hinge right? I open that up all the way to bare wire took all the tape out and goes into the rear seat next to the pioneer electronic device. how far am i suppose to follow that wire set into?
