sherlockshah Posted April 18, 2009 Share Posted April 18, 2009 IS that normal? the back wheels are spinning forward but the car is not in gear? also P R D is lit up and car wont shift out of first gear, does the computer think the car is in reverse and stays in one gear? Quote Link to comment Share on other sites More sharing options...
Lucky13 Posted April 18, 2009 Share Posted April 18, 2009 Quote Link to comment Share on other sites More sharing options...
amcdonal86 Posted April 18, 2009 Share Posted April 18, 2009 Sounds like you need to check your trunk wiring harness. No it's not normal for your wheels to be turning when the car is in neutral. Quote Link to comment Share on other sites More sharing options...
sherlockshah Posted April 18, 2009 Author Share Posted April 18, 2009 Sounds like you need to check your trunk wiring harness.No it's not normal for your wheels to be turning when the car is in neutral. I checked it , the one on the drivers side, i opened up the whole thing there are no cuts or lose connections, :( I am suppose to look at the one that goes under the plastic cover that lines up with the trunk hinge right? I open that up all the way to bare wire took all the tape out and goes into the rear seat next to the pioneer electronic device. how far am i suppose to follow that wire set into? Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted April 18, 2009 Share Posted April 18, 2009 In case you haven't seen... http://www.lexls.com/tutorials/lighting/bulbout.html Quote Link to comment Share on other sites More sharing options...
