1995 Ls 400 Check Engine Codes.
Edgar Picazo
P0304 = Cylinder 4 misfire
P0300 = Multiple Cylinder misfire
P0303 = Cylinder 3 misfire
P0305 = Cylinder 5 misfire
P0307 = Cylinder 7 misfire
Looks like a bank is running like crap. Did you replace your Cap, Rotor, and wires? Is so, might be the coil for that bank.
Sorry did not mean to sound like a smart !Removed!, I don't know anything about codes but after researching I found what you guys posted, I have not changed wires nor plugs, should I do that first before I invest in coils what do you guys suggest and where can i buy at decent price.
Thank you all.
Ps what is a cap?
Thank you all, I will follow your instructions and keep you posted.
Best regards.
If you have a multimeter, you can test the resistance of your Spark Plug wires and igntion coils, and see if they are within spec... :)
