IS250_rookie Posted February 8, 2009 Share Posted February 8, 2009 I pumped up the tires to 33-35psi (30 is needed)...but the low tire pressure warning won't go away. Could it be that one of the TPMS broke? The car is just over a year old...it worked fine before. Quote Link to comment Share on other sites More sharing options...
jgr7 Posted February 8, 2009 Share Posted February 8, 2009 Did you get the spare tire also? Jeff Quote Link to comment Share on other sites More sharing options...
rx350guy Posted February 8, 2009 Share Posted February 8, 2009 Agree that you need to check the spare....which is usually the problem.. Quote Link to comment Share on other sites More sharing options...
IS250_rookie Posted February 8, 2009 Author Share Posted February 8, 2009 No i didn't, thanks I'll try that and see what happens. Quote Link to comment Share on other sites More sharing options...
rx350guy Posted February 8, 2009 Share Posted February 8, 2009 No i didn't, thanks I'll try that and see what happens. Be sure to let us know what you find out.. :) Quote Link to comment Share on other sites More sharing options...
googs Posted February 9, 2009 Share Posted February 9, 2009 Put some nitrogen in your tires...helps with the pressure from going low and setting off the sensors. Quote Link to comment Share on other sites More sharing options...
IS250_rookie Posted February 11, 2009 Author Share Posted February 11, 2009 Checked all tires. The 4 that are on the car are at 34psi. The spare is at 33psi. So there must be something with the TPMS...could it be a fuse? Well actually that won't make sense since it just wouldn't show up. p.s.: Everytime I click Fast Reply I can't start typing right away. The window becomes like a link for some ad, and then I have to come back to the forum. Quote Link to comment Share on other sites More sharing options...
pauljcl Posted February 11, 2009 Share Posted February 11, 2009 Checked all tires. The 4 that are on the car are at 34psi. The spare is at 33psi. So there must be something with the TPMS...could it be a fuse? Well actually that won't make sense since it just wouldn't show up.p.s.: Everytime I click Fast Reply I can't start typing right away. The window becomes like a link for some ad, and then I have to come back to the forum. I would say something is wrong with one of your sensors. I had same problem - new car, they didn't check tire pressures prior to delivery, and it got colder that night. Coming out of a restaurant, the new car shows the tire pressure warning light. I thought I had picked up a nail or something (aren't the dealers supposed to deliver a car with correct air pressure in the tires?). To cut to he chase, four tires (incl. spare) were at 26 psi, one at 25 psi. Blowing up that one made the tire pressure monitor turn off. (So I assume the threshhold is 25psi???). I put all the tires at 32 psi, higher on the spare (what a convoluted system!!!), and all is well. I concluded that the TPMS re-sets by itself (it doesn't in the BMW - got to go to the dealer to reset for my 2005) which is to the credit of Lexus. Did you call your dealer? for his input? Quote Link to comment Share on other sites More sharing options...
pauljcl Posted February 15, 2009 Share Posted February 15, 2009 Checked all tires. The 4 that are on the car are at 34psi. The spare is at 33psi. So there must be something with the TPMS...could it be a fuse? Well actually that won't make sense since it just wouldn't show up.p.s.: Everytime I click Fast Reply I can't start typing right away. The window becomes like a link for some ad, and then I have to come back to the forum. well --- surprise! I just saw in the Manual for the RX350 that, below the steering column (and above your legs) there are three buttons. The left one is - if have the option - a height control switch, the middle one is the tire pressure warning reset switch - and the right one is the VSC 'off' switch. Maybe your IS also has a hidden Tire pressure warning reset button??? Quote Link to comment Share on other sites More sharing options...
IS250_rookie Posted February 17, 2009 Author Share Posted February 17, 2009 Checked all tires. The 4 that are on the car are at 34psi. The spare is at 33psi. So there must be something with the TPMS...could it be a fuse? Well actually that won't make sense since it just wouldn't show up.p.s.: Everytime I click Fast Reply I can't start typing right away. The window becomes like a link for some ad, and then I have to come back to the forum. well --- surprise! I just saw in the Manual for the RX350 that, below the steering column (and above your legs) there are three buttons. The left one is - if have the option - a height control switch, the middle one is the tire pressure warning reset switch - and the right one is the VSC 'off' switch. Maybe your IS also has a hidden Tire pressure warning reset button??? I only needed this info for the RX350. Thanks a lot, I'll try that. Quote Link to comment Share on other sites More sharing options...
