Ratatat Posted January 6, 2009 Share Posted January 6, 2009 had an astrostart installed in the ES300, if unlocked the car starts, if locked it goes into an alarm condition, but if you hit unlock, alarms stops and vehicle starts, if you hit lock then start then it starts, i suppose the 1 minute wait period, but then it wont alarm, if you hit the truck, it alarms, unless you unlock doors first, then no alarms. At this rate the low temp sentinal is useless, because it will alarm. What is going on? Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted January 6, 2009 Share Posted January 6, 2009 Which model did you have installed? Sounds like you'll probably just need to take a few minutes to program it.. Quote Link to comment Share on other sites More sharing options...
Ratatat Posted January 6, 2009 Author Share Posted January 6, 2009 either the RSS-2524 or the RSS-2504A I will find out for sure today to post, on the back of the remote, the wife said it has TX60A on it. Quote Link to comment Share on other sites More sharing options...
Ratatat Posted January 6, 2009 Author Share Posted January 6, 2009 I was told it was a 2504A that was installed Quote Link to comment Share on other sites More sharing options...
Ratatat Posted January 6, 2009 Author Share Posted January 6, 2009 http://www.astroflex.com/index.php?module=...=20&page=20 Quote Link to comment Share on other sites More sharing options...
SAMOHT023 Posted January 7, 2009 Share Posted January 7, 2009 http://www.astroflex.com/index.php?module=...=20&page=20 SEEMS TO ME THAT THE FACTORY ALARM ISN'T BEING DISENGAGED WHEN THE REMOTE START SYSTEM ACTIVATES THE IGNITION. THE UNLOCK/FACTORY ALARM DISARM WIRE IS AT THE THEFT ECU BEHIND THE GLOVE BOX OR PASSENGER KICK PANEL. IT IS YELLOW/BLUE AND NEGATIVE IN POLARITY. THERE SHOULD BE A WIRE FROM THE REMOTE START MODULE THAT SENDS GROUND TO THE UNLOCK/FACTORY ALARM DISARM WIRE TO DISARM THE FACTORY ALARM WHEN THE REMOTE START SYSTEM IS ENGAGED. YOUR WIRING WOULD HAVE TO BE INSPECTED BY A TECHNICIAN TO CONFIRM THIS. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted January 12, 2009 Share Posted January 12, 2009 Agreed the oem alarm disengage from the alarm to the alarm ecu is not connected. Quote Link to comment Share on other sites More sharing options...
