Car Died :( Please Help!
PPK321
I have an old 1st generation LS400. It recently had some problems with the alternator so I got a new one and it worked for a couple weeks. But after these couple weeks my car won't start anymore and when it does all the lights pop up on the dash.
I got a new battery but the car still won't start. Now the radio or anything won't start up. I tried jumping it but the car still has all the precaution lights on the dash.
Is this a problem with the battery, connection, or is it the starter?
All help would be highly appreciated.
does the engine turn over, fire, but don't start.....ect? give some more specific details.
in the mean time check all of you connections, battery, alter. ground wires.
And check the wire harness that runs through the drivers side trunk hinge. pull the trunk liner down and the black trim strip off the hinge. unwrap the wires and look for bare or broken wires. Do a search for trunk hinge wire. common issue that gives many different problems.
