thenewmexican Posted October 26, 2008 Share Posted October 26, 2008 My 1991 LS400 Has noticeable black smoke coming from both tail pipes. The smell of the smoke is highly toxic. And. Even finds it way into the passenger cabin. Could it be the MAF sensor or ?? Any pointers are greatly appreciated. Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted October 27, 2008 Share Posted October 27, 2008 black smoke??? sounds like you're burning oil... Quote Link to comment Share on other sites More sharing options...
python Posted October 27, 2008 Share Posted October 27, 2008 oil isnt black, fuel is...... Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted October 27, 2008 Share Posted October 27, 2008 Too much fuel. Blue smoke is burnt oil. Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted October 27, 2008 Share Posted October 27, 2008 oil isnt black, fuel is...... :whistles: oops... its been a while since I've seen smoke actually coming out of an exhaust. Quote Link to comment Share on other sites More sharing options...
SRK Posted October 27, 2008 Share Posted October 27, 2008 My 1991 LS400 Has noticeable black smoke coming from both tail pipes. The smell of the smoke is highly toxic. And. Even finds it way into the passenger cabin. Could it be the MAF sensor or ?? Any pointers are greatly appreciated. First thought is one of the pre-cat oxygen sensors. You should have a code though. If the engine is misfiring heavily it could be a bad injector, or if no power, a bad ignition coil, and neither of those will pop a code. Quote Link to comment Share on other sites More sharing options...
thenewmexican Posted October 28, 2008 Author Share Posted October 28, 2008 My 1991 LS400 Has noticeable black smoke coming from both tail pipes. The smell of the smoke is highly toxic. And. Even finds it way into the passenger cabin. Could it be the MAF sensor or ?? Any pointers are greatly appreciated. First thought is one of the pre-cat oxygen sensors. You should have a code though. If the engine is misfiring heavily it could be a bad injector, or if no power, a bad ignition coil, and neither of those will pop a code. Thanks for the help everyone. The diagnostic codes say 24 and 31. Which both point to the MAF sensor. However I checked the MAF resistance at 72F, and it was 2K. My understanding is that between 2K-3K @ 68F is the correct resistance. So. What else could it be. Coil ?? ECU ?? Thanks again. Quote Link to comment Share on other sites More sharing options...
python Posted October 29, 2008 Share Posted October 29, 2008 what exactly are those codes? saying that they point to the maf is too vague Quote Link to comment Share on other sites More sharing options...
thenewmexican Posted October 29, 2008 Author Share Posted October 29, 2008 what exactly are those codes? saying that they point to the maf is too vague 24 - Intake air temp. sensor signal 31 - Air flow meter signal Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted October 29, 2008 Share Posted October 29, 2008 I would've thought a bad coil... but as I've proven a few post before... i can be wrong. :( do your cats get red hot? Quote Link to comment Share on other sites More sharing options...
