Help Me Please?
donte623
last friday,i've put gas in my 94 ls before heading out w/friends,the following sat afternoon,i was leaving my apt complex and stepped on the gas,the car started to jerked and bucked like a wild horse!!!it was like i couldn't go anywhere!!when i drive the car normal,it rides like there is nothing wrong,only when i try to pass or go fast thats when the "check engine light"comes on then it goes off after i take my foot off the pedal to drive normal!!i've put new wires,distributors ,rotors,dry gas in which it needed it!!!but the car is still doing the same thing!! :angry: my brother(mechanic thats to far from me)say it could be my ignition coils going bad or fuel filter needs to be change or the fuel pump is bad!!!! :o !is there a tutorial on how to changed the coils!! i need help!!!!! i been reading some of the threads here about the "Dreaded Trunk Wires" that can cause the problems!if so,what kind wire (gauge) do i need to replaced!! please someone have a tutorial on this also!!!!
Yes, the broken wires in the left trunk hinge can cause this problem.
Here are some instructions: http://www.lexls.com/tutorials/lighting/bulbout.html I had to fix this on the 90 LS I used to have.
found the problem,it was my altenator wire that was corroded(from the alt)that was robbing me of my power to the engine,in which i couldn't go faster as expected!! does anyone know where i can get this wire from??????
I have found Rich Industries to be a good place for small parts like that. Their prices are very reasonable and they usually do not have a problem shipping small parts outside of the Kansas City area. www.rich-industries.com
