billydpowell Posted August 12, 2008 Posted August 12, 2008 how do you reset the brake pad warning light
jcrome04 Posted August 12, 2008 Posted August 12, 2008 Might help to have the year of your vehicle?? If you don't have a reader that you can use to reset lights maybe just unhook the battery for a while or pull the ECU fuse? Kill 2 birds with 1 stone and reset your ECU mappings while your at it! :D I did this and it seemed to help my car run a little better. I'm not an expert in this field so, don't quote me boy :D
cmk033 Posted August 26, 2008 Posted August 26, 2008 how do you reset the brake pad warning light Brake pad warning light is only available from 93 model and on. This is not something that can reset. There is a pair of ceramic warning device that is installed on your brake. This device must be replaced. Each cost I think about $50 from dealer.
mnesbit Posted August 26, 2008 Posted August 26, 2008 how do you reset the brake pad warning light Brake pad warning light is only available from 93 model and on. This is not something that can reset. There is a pair of ceramic warning device that is installed on your brake. This device must be replaced. Each cost I think about $50 from dealer. The circuit is broken when the brake pad light goes on. So it has to be replaced and there is one for the front brakes and one for the rear set. My warning light just went on with 10% pad left on the rear brakes.
Carmelsteve Posted August 26, 2008 Posted August 26, 2008 You could just jumper the sensor wires together at the brakes. This would, of course disable the warning system, and so I don't recommend it, but it would get rid of the warning. The new sensors are about $60, if you decide to replace it. By the way, if you replace the sensor, some people are cable-tying the sensor up away from the brakes to avoid having to replace them in the future, but again, you lose the warning system. Steve
dfkd Posted August 26, 2008 Posted August 26, 2008 Unless you happen to be in Canada where I was quoted a whoping $110 each.
cmk033 Posted August 26, 2008 Posted August 26, 2008 You could just jumper the sensor wires together at the brakes. This would, of course disable the warning system, and so I don't recommend it, but it would get rid of the warning. The new sensors are about $60, if you decide to replace it. By the way, if you replace the sensor, some people are cable-tying the sensor up away from the brakes to avoid having to replace them in the future, but again, you lose the warning system. Steve Are you sure the jumping would shut off the light? I try this and it did not work. What method did you use to jump? Thanks in advance for your reply.
billydpowell Posted August 26, 2008 Author Posted August 26, 2008 You could just jumper the sensor wires together at the brakes. This would, of course disable the warning system, and so I don't recommend it, but it would get rid of the warning. The new sensors are about $60, if you decide to replace it. By the way, if you replace the sensor, some people are cable-tying the sensor up away from the brakes to avoid having to replace them in the future, but again, you lose the warning system. Steve Are you sure the jumping would shut off the light? I try this and it did not work. What method did you use to jump? Thanks in advance for your reply.
billydpowell Posted August 26, 2008 Author Posted August 26, 2008 You could just jumper the sensor wires together at the brakes. This would, of course disable the warning system, and so I don't recommend it, but it would get rid of the warning. The new sensors are about $60, if you decide to replace it. By the way, if you replace the sensor, some people are cable-tying the sensor up away from the brakes to avoid having to replace them in the future, but again, you lose the warning system. Steve Are you sure the jumping would shut off the light? I try this and it did not work. What method did you use to jump? Thanks in advance for your reply. someone told me to strip the insulation back at the sensor and twist the two wires together. will this work?? also my 94 LS seems to have one on each wheel, do all 4 of them have to be twisted together?
billydpowell Posted August 26, 2008 Author Posted August 26, 2008 also, do you have to CUT the wires, or just twist them together???
dfkd Posted August 27, 2008 Posted August 27, 2008 Essentially there are 2 wires in the sensor. When the brakes are worn the sensor rubs on the rotor, breaking the connection between the wires. To bypass the sensor, thus disabling the warning light, simply expose the wire (most people cut off the top of the sensor and strip the plastic housing off the wire) and connect the wires, closing the circuit. The light will go off.
billydpowell Posted August 27, 2008 Author Posted August 27, 2008 Essentially there are 2 wires in the sensor. When the brakes are worn the sensor rubs on the rotor, breaking the connection between the wires.To bypass the sensor, thus disabling the warning light, simply expose the wire (most people cut off the top of the sensor and strip the plastic housing off the wire) and connect the wires, closing the circuit. The light will go off. I stripped all my wires and twisted them together, light stayed on. tomorrow I will cut the wires from the sensor and see if that works. I done all 4 wheels. if it works I will post it.
N.C.O. Posted August 28, 2008 Posted August 28, 2008 Essentially there are 2 wires in the sensor. When the brakes are worn the sensor rubs on the rotor, breaking the connection between the wires.To bypass the sensor, thus disabling the warning light, simply expose the wire (most people cut off the top of the sensor and strip the plastic housing off the wire) and connect the wires, closing the circuit. The light will go off. I stripped all my wires and twisted them together, light stayed on. tomorrow I will cut the wires from the sensor and see if that works. I done all 4 wheels. if it works I will post it. The sensors are only on the right side, one front and one rear; the sensors are there so you won't wear the pads down to metal, which in turn might ruin the rotors. Replace the sensors and do frequent routine brake inspection would be the best way to go, instead of disabling a warning system that would warn you of unforeseen problems if by chance you forgot to have the brakes check. Good Luck, N.E.O. Correction to the above, 94 LS400 has sensor on all four wheels; in 1995, they were change to only the right side pads.
billydpowell Posted August 29, 2008 Author Posted August 29, 2008 Essentially there are 2 wires in the sensor. When the brakes are worn the sensor rubs on the rotor, breaking the connection between the wires.To bypass the sensor, thus disabling the warning light, simply expose the wire (most people cut off the top of the sensor and strip the plastic housing off the wire) and connect the wires, closing the circuit. The light will go off. I stripped all my wires and twisted them together, light stayed on. tomorrow I will cut the wires from the sensor and see if that works. I done all 4 wheels. if it works I will post it. The sensors are only on the right side, one front and one rear; the sensors are there so you won't wear the pads down to metal, which in turn might ruin the rotors. Replace the sensors and do frequent routine brake inspection would be the best way to go, instead of disabling a warning system that would warn you of unforeseen problems if by chance you forgot to have the brakes check. Good Luck, N.E.O. Correction to the above, 94 LS400 has sensor on all four wheels; in 1995, they were change to only the right side pads. NOTICE, my error, I had failed to strip ALL the insulation off on one pad, and it was preventing the wires from contacting. Luckly it was the first one I was going to cut... now the light is out. NO CUTTING. and with new sensors the warning system would be operating again.. .
