Tires Ls400`
Huskyak
Hi all,
Been looking around for a set of four P255/60R16 'V' rated tire tires for my 1995 LS400.
Firestone dealer has suggested the following: Bridgestone Turanza LS-H 225/60/16. H rated, (rated 130 mph) 'A' traction and 'A' temperature rating.
I believe Lexus calls for a 'V' rated tire which is rated about 140 mph. This is just a little bit too fast for me. 'H' rated gives me 130 mph, which I still don't think I'll ever attain.
Will some the members be kind enough to share your opitions, both pro and con, regarding the Bridgestone Turanza 225/60/R?
Thanks.
CanadaCraig did a lot of research on this in the LS forum - did a great job.
But - it may have been lost in the great "crash"..... ;)
Anyway,
the Turanza got GREAT REVIEWS!! WET/DRY/SNOW/TRAC/TREADLIFE/ and most important...
VERY QUIET. Sounds like the best tire out there. He has them ordered and will have them on within a week or so.
He got the "v" rate tire because all the specs were superior to the H and T
Go to TIRERACK.COM and you can find your way to a CHART COMPARISON....
I need some new ones Too! If they are as good as they rate out; then their worth the $ :D
Hi Huskyak!! :)
Read the messages [if you like] in the following 'topic'.
Bridgestone Turanza LS tire Information
On Tuesday [December 16th] I had my Michelin X-One's replaced with brand new Bridgestone Turanza LS-V's. I'll let you know what I think of them after I've had a chance to drive the car more. [my car is at the Lexus dealer - until Thursday - having the a/c filter replaced and a wheel alignment done - plus a couple of other things]
I hope that helps!!
Craig!! :D
ps thanks for the pat on the back 99lsguy!! :D
