rpboy06 Posted June 1, 2008 Share Posted June 1, 2008 Hey guys, I was wondering how long of an extension am I going to need to reach the spark plugs using my socket wrench? Quote Link to comment Share on other sites More sharing options...
cmmetcalf Posted June 2, 2008 Share Posted June 2, 2008 Hey guys,I was wondering how long of an extension am I going to need to reach the spark plugs using my socket wrench? Varies. I use a wobbly head 3/8" drive with 6" extension with a 5/8" Plug socket (has rubber plug holder in it---not a standard one) or you can't get the plug out after it is loose. On some models I also use a 3/8" universal joint on the plug socket end in order to get the whole assembly in. I usually use anti-seize on the plug threads (do not get it on the electrode). I mount the 3/8" universal joint on the plug socket add the extension and screw the plug in until hand tight. Then I stick the rachet on and finish it up. Don't overtighten. Quote Link to comment Share on other sites More sharing options...
