My 98 With 10 Months No Detailing And 6 Onr
mburnickas
Quick background: Moved down south and moving out. But 10 months and over 25K miles here is the outcome. No before since it was start at 5:35 am.. Drove up back up in Northeast (bought a house) and selling house in Spanish Country!
Just did a quick 156 minutes external detail. I know the time since the sons blankets where in the steam dryer and it just finsihed when I put equ away!
1. Washed with Optimum No Rinse Wash & Shine;
2. Clayed (yellow) using Blue Mist Final wipe as Lube...
3. Applied Jeff Werkstatt Prime Acrylic, Makita 9227C using LC white pad @ 1,100 rpms.
4. Applied Jeff Werkstatt Acrylic Jett Trigger with LC Blue pad @ 1,2000 RPMS on Makita.
5. Used Chemical Guys Liquid Extreme Shine on lower plastic (under doors).
6. Used ONR on rims and tires (lazy) .
7. Tires where cleaned with Optimum Tire shine.
8. Rims sealed with PB EX-P. Left to dry entire time, then wipped.
1 out of 10 it looks like maybe a 6..
Ok, I'm confused here. So let me try to get this straight.
10 months ago you did a full detail? and now you just redetailed it? or what you just did you don't consider a detail, and here is what it looks like 10 months after a real detail?
Yes on the 10-months ago. And yes I just re-detailed it after 10-months. I said the detail, after 10-months does not look that great. Just showing how JW holds up.
