Zdeno Posted December 9, 2003 Share Posted December 9, 2003 Does anybody know where is the best place to drain off the water from my 1991 LS 400 ?? I need to change water because I have a air in cooling system ( guys from here guess that ) and don´t know where to drian it off. Thanks Quote Link to comment Share on other sites More sharing options...
mejojo Posted December 9, 2003 Share Posted December 9, 2003 See the bottom section on disposal of coolant. Coolant Disposal Joe Quote Link to comment Share on other sites More sharing options...
spiller91ls Posted December 10, 2003 Share Posted December 10, 2003 There are two drain valves on both sides of the engine block, you have to remove the plastic cover from the bottom of the car to get to them, also you fill the engine with coolent from the fitting where the thermistat housing is( the fitting on top). Quote Link to comment Share on other sites More sharing options...
99lsguy Posted December 11, 2003 Share Posted December 11, 2003 If you leave the bottom cover on..... Does the coolant drain (maybe) to a certain area or do you think it just goes EVERYWHERE? Quote Link to comment Share on other sites More sharing options...
tansupplyman Posted December 13, 2003 Share Posted December 13, 2003 Zdeno, don't know if you have done the drain yet, it not ,here is more verbage. Take the bottom cover off(10mm); the drains on the engine[one on each side] are accessable between the track bar entensions and the aluminum subframe. The 10mm bolt heads are brass---use a ratchet with about 12" of extensions; also you will need approx. 24" of 3/8" ID hose. Put the hose on the outlet extension next to the bolt head and direct into a container. DO NOT take the bolt out; after turning a few turns the coolent will flow out of the hose. flows for about 15 min per side. remember to take off the cap or disconnect the rad hose connecting to the thermostat housing,--might want to open the air relief on top of the thermostat housing. of course, the radiator drain is very obvious !! good luck. Quote Link to comment Share on other sites More sharing options...
