17LexusOwner Posted April 17, 2008 Share Posted April 17, 2008 I recently had to have my coolant resivoir because of a leak. Now I've noticed that my temp gauge is higher then normal (normal is the first bar) now it is at the second-third bar. My dad told me that there is a bubble in the line preventing proper cooling. My question here is, is there a air release valve on the hose itself for a bubble like this? Quote Link to comment Share on other sites More sharing options...
qha_vn Posted April 17, 2008 Share Posted April 17, 2008 i believe your car is fine with coolant temp needle is at second-third (middle of the gauge range) temp wasnt ideal on 1st bar (too cool) Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted April 17, 2008 Share Posted April 17, 2008 Mine stays barely above the 3rd line.... it was the same with my old LS as well. Quote Link to comment Share on other sites More sharing options...
chilkoot Posted April 17, 2008 Share Posted April 17, 2008 mine also sits about 1/8" above the third (halfway) mark, doesn't move once it warms up. when I had a bad thermostat it stayed at the second line, pegged solid. Quote Link to comment Share on other sites More sharing options...
NewGuy19 Posted April 17, 2008 Share Posted April 17, 2008 Before my new water pump my temp gauge would sit about half way between the third and fourth line. After I did the water pump/timing belt and also the coolant reservoir due to a leak, I now run about an 1/8" below the third line. Quote Link to comment Share on other sites More sharing options...
17LexusOwner Posted April 17, 2008 Author Share Posted April 17, 2008 oh, nvm then i guess my car was just running too cool before. glad to know that it is normal and i don't have to do a repair. thanks for the help Quote Link to comment Share on other sites More sharing options...
vyhanh Posted April 18, 2008 Share Posted April 18, 2008 My 91 shows the 2nd line (if counting half/midway as 3rd) in winter. Now it's midway once warmed Quote Link to comment Share on other sites More sharing options...
